It is currently Wed Jul 23, 2025 6:39 am
PostPosted: Sat Apr 07, 2007 11:46 am
I am doing my first french polish finish on a classical I am building.
Aside from the pore filling (arghhh!!!) I am getting a nice build on the back sides and neck.
My problem is the top.I am on my third session and it just doesn't seem to want to build on the top (carp spruce).
I am doing the exact same thing as on the rest of the guitar,so naturally I think it has something to do with the texture of the spruce.
Any advice from the french polisherati??
PostPosted: Sat Apr 07, 2007 12:26 pm
Hi Brad,
It is hard to know exactly what is wrong without seeing your guitar and
your technique. Shellac sticks to just about everything - so I'm guessing
there is a technique problem more than a potential issue with your
Carpathian top.
1) My initial suggestion is to inquire about your muneca and what it is
made of. Not all munecas are created equal. Lamb's wool is the best
core and it does make the process easier. I have also found that a well
worn cotton men's dress shirt is awesome covering material - much
better than muslin, IMHO.
2) The second suggestion would be to check out Milburn's online
tutorial. Specifically about loading the muneca. You might be adding too
much alcohol and spiriting away the freshly deposited shellac. Also, I
cannot emphasize enough how important it is to do a blot test on a piece
of paper after loading the muneca and before you touch the finish. Too
much and you will destroy your finish in seconds and too little will take
you forever to deposit a finish of suitable thickness.
I charge my muneca many, many times during the course of a session and
tend to favor going with a drier pad than a wetter one. You can really
press into the finish with a drier muneca which will make for a harder
final finish.
Let us know if this doesn't help. There is always the possibility that there
is an unknown issue with the top - although, I do think this is unlikely.
And yes, pore filling the traditional route is a major headache. I suggest
using epoxy in the future - it will make the French Polishing experience
much more enjoyable.
Once you get the hang of it, there is no other finish that is as good
tonally and visually. Of course, that is just my opinion.
Peace Out,
Simon
PostPosted: Sat Apr 07, 2007 12:30 pm
Hi Brad,
I just read Hesh's response. That is a definite possiblity as well and might
be the most obvious solution. My technique usually has me having a
decent gloss finish after the second session - but this will vary from
person to person.
You might just want to try a couple more sessions on the top - you can
do a couple a day with no problem and see if you haven't gotten a film to
develop.
Best of luck,
Simon
PostPosted: Sat Apr 07, 2007 12:43 pm
Simon,
I am using Milburnes tutorial as my "bible".
I am using well worn,soft cotton tee shirt material for the covering of the muneca with a rolled up gauze interior.
I think I am loading the muneca properly-I have been doing the blot test as well.
It just seems to be working "perfectly" on the back,sides and neck.
I had a decent gloss after the first session.
I will try a few more sessions and see what happens.
I have to agree with you,that it is the most beautiful finish-really makes the wood "pop".
Brad
PostPosted: Sat Apr 07, 2007 12:51 pm
Hesh,
I used regular pore filler for the back and sides-hopefully a couple more sessions should bring the top up to the gloss of the rest of it.
Brad
PostPosted: Sat Apr 07, 2007 3:10 pm
Brad, based on what you've said. If you are getting good results on the
back & sides - it should work on the top, eventually. What Hesh said
about the pore filler does make a lot of sense to me. Please let us know
how it turns out and if we can be of any help.
For what it is worth, I learned from the MIlburn tutorial as well - although,
my schedule is a bit different. I do 8 sessions. Two sessions each day
and each session takes me about 2 hours. After the 8 sessions, I wait one
week (very important to wait) before leveling with 600 grit paper and then
start the glazing process. I do 6 glazing sessions. I wait 4 days and then
use Meguiar's Plastic Polish and then Plastic Cleaner. It is a lot of work
but the resulting finish is beautiful.
Peace Out,
Simon
PostPosted: Sat Apr 07, 2007 4:26 pm
I just finished my first french polish also. Going on what has been said already, waiting between sessions is one of the most important. If Milburn mentioned this, I must have skipped over it.
It did seem to take me longer to get the finish on the top also. After I had let it sit for several days with nothing being done to it and then coming back, things really sped up and I was able to get the shine I was looking for.
PostPosted: Sun Apr 08, 2007 12:06 pm
How do you guys do a session? By that I mean, do you do the back and one side and the the top and the second side to allow for working the body or do you do the back and finish it, and then the sides??? WHat is your order.
PostPosted: Mon Apr 09, 2007 12:51 am
Rich,
I consider a session going over the entire guitar.
I start with the back,then do both sides then the top,then the neck.
I work on a piece of paper and the shellac dries so fast I can turn it on the side with no problem.
PostPosted: Thu Apr 12, 2007 1:46 pm
Thanks Brad
I may be making more of this than needed. I read somewhere that recommended to do back and one side and then do top and other side. I seem to have slight trouble handling the body during the process. Thanks for your response
PostPosted: Thu Apr 12, 2007 1:52 pm
I am the worst at following directions. Here is what I do. Appreciate any feedback.
Start with 2lb cut shellac and fairly dry muneca. Start with small circles and expand to larger circular pattern and then finish with strokes following grain. Then I go over again with a couple drops of alcohol loaded into the muneca to remove some of the marks and swirls following same pattern. A session for me will be two times the above process.
I do this 4-5 times and then sand with felt block and 500 grit paper (water). Last session I switch to 1 lb cut and do the same as above.
Seem to be getting good results - mirror finish with little or no buffing required although I just bought some fine polishing compound from LMI to see if I can remove the final imperfections by hand.
How does this sound to those of you who have experience?
PostPosted: Fri Apr 13, 2007 6:42 am
The only thing I know of that would be different is if you were using too much alcohol when padding you can cause the shellac to thin enough to penetrate the spruce. However if you did the sealing as described in the Milburn tutorial that should not be the issue. The other is if you use an extra wet pad, either shellac or alcohol you can actually remove more shellac than you lay down. When this is happening it is not likely to happen consistent over the top but rather in the areas where you start each load.
PostPosted: Fri Apr 13, 2007 8:20 am
[QUOTE=Hodges_Guitars]
You need to allow the previous shellac to gas off. This should take about 15 min. The longer you allow the better to a point. I like to wait about 1 hour.
